It would be great to have functionality for handling errors in the timeXtender REST connector (and maybe other connectors as well). When using dynamic values some APIs will return 403 error when user doesn’t have access to the endpoint, or there is no record for that dynamic value. It can often be related to newly created entries, so not always easy to filter away manually.
Maybe a simple checkbox to be able to go to next dynamic value upon error. Or more advanced, to be able to make a list of error codes and the handling:
Error code
Handling
Wait
403
Continue with next record
0 sec
429
Retry
60 sec
401
Stop
404
0 sec
Originally posted on the Timextender Community (Gainsight), 2025-04-03, with 13 votes.
We've encountered the same issue while connecting with two different APIs the past month. In the first instance we we're able to negotiate the response with the API developer. In the second case the developers on the other side didn't have this flexibility.
Seems valid to add a form of error handling for REST connections in the TimeXtender REST provider. Lots of APIs give error responses with dynamic values, but this doesn't necessarily have to mean that the execution in TX should break.
Would be nice to be able to add exceptions for certain error codes. E.g. set up that if the error code 400 is raised handle this by continuing with the next dynamic value, for all other errors use the default handling.
