My Azure SQL ERP source does not have a lastmodified datetimestamp on the tables. We’re investigating the options to enable change data capture (CDC) or change tracking (CT) on the biggest tables.
How would I proceed with further setting this up with TimeXtender? I can't find any related manuals, blogs or sources for this.
Thanks in advance!
Originally posted on the Timextender Community (Gainsight), 2026-10-15.
As far as I know, CDC or CT is not supported. Do you have a creationdate or another date field available in your data?
Maybe you could use that field and subtract a certain number of days from it to make sure you capture all the changes. It’s not the most ideal solution, but at least you would have some sort of incremental load.
