I have encountered an issue after upgrading the TX EnhancedREST Connector from version 1.10.2 to version 1.15.0.
The problem did not occur when using version 1.10.2.
Our environment consists of a single TimeXtender server hosting both DEV and PROD environments.
Since upgrading to version 1.15.0, i am no longer able to create new Data Sorce using TX Enhanced REST Connector v. 1.15.0 in PROD (DEV works fine). However, creating connections with version 1.10.2 continues to work without any issues in both PROD and DEV
I am a bit reluctuent to re-/uninstall 1.15.0 because i have a datasource in DEV with 15 endpoints that use 1.15.0.
Originally posted on the Timextender Community (Gainsight), 2026-10-06.
I tried it in Timextender Classic 26.3.0.0 which was released on the 8th of October and also on version 26.3.0.1 which was added yesterday both with version 1.15.0
It worked fine as you can see in the video I attached.
You added this on the 6th. I don’t know if they added the new versions first, but it seems like they fit the best with a newer version of the program.
@Thomas_Lind I created a ticket for this issue, and the engineer who was assigned the ticket told me that i do not need to upgrade to the last versjon of TX. You can look at the comment posted at September 7, 2026 at 3:20 PM on the ticket
